Peržiūrėti neatsakytus pranešimus | Peržiūrėti aktyvias temas Dabar yra 24 Spa 2026 17:26
Atsakyti į temą  [ 5 pranešimai(ų) ]
 yamaha grizzly clutch kit
Užsiregistravo: 14 Rgs 2013 21:04
Miestas: utena
sveiki taigi pasidomejau apie grizzlio sankabos apsuku pastiprinima (torque monster clutch kit) gal kas nors esate tai pasidare? ar tai veiksminga? jai esate naudoje kokie + bei -? ir gal zinote is kur gauti?
29 Lap 2013 21:44
paprasciausias clutch kit su lengvesniais svareliais. Ivertink tai kad jei isvietos kils su cemento maisu tai max greitis bus 50 - 60 kmh. amerikonai juos deda kai yra dideles padangos kad motociklas neprarastu galios, o greicio jiems nereikia purvo balose. Ar tave tenkintu 50kmh ir kaukiantis motoras?
30 Lap 2013 13:44
Grizzly 700 tiuninginė sankaba. Deja dedama ne dėl bandymo kas geriau , o todėl kad pigiau nei originali :)
n the Dr.Pulley HiT clutch two sets of springs are working: The clutch spring, inside, controls through the centrifugal power the movement of the clutch pads towards the clutch bell (for example at 3000 rpm). The second set of "torque" springs, externally mounted, controls then the pressure by using a "push pin" on the clutch linings (in the example already at 3400 rpm) against the bell, thus preventing most of the slipping phase of the clutch. Because of less friction, much less heat is generated. heat is lost power. The ATV accelerates much faster because the full power transmission to the rear tyre already exists at 3,400 rpm, instead of 4000rpm with a normal clutch.
The HiT clutch is very effective while driving with frequent speed changings: To accelerate out of curves or at mountain trips. Or for a powerful overtaking. The graphs show a marked increase in speed and performance especially in low and medium speed ranges.
With the two fully enclosed sets of spring , the clutch can be customized to all personal needs. For example, if you want to get more power at start, choose a stronger clutch spring to increase the starting rpm. If you want to shorten the slipping phase of the clutch, you should select a weaker pillow (torque) spring. Extreme: To get an extreme start (wheely), choose a strong clutch spring, and a very weak (or no) pillow (torque) spring.
For those who do not want to experiment long, an average spring combination is already installed with delivery.
Importatant: Together with the HiT high performance clutch the use of not too light vario weights is strongly recommended. The best result you get with Dr.Pulley slider rolls with the same weight like the original or 5-10% lighter.
31 Lie 2015 14:27
Užsiregistravo: 27 Spa 2015 09:14
Pranešimai: 2
Miestas: taurage
Technika: grizzly 700
Is kur uzsisakiai sankaba kokia kainyte.
lauksiu ziniu nes labai reikia sankabos
27 Spa 2015 20:09
Pranešimai: 2
Miestas: taurage
29 Spa 2015 22:18
