Enduro rally I etapas, TOME, Latvija
tomasbrp
Apskritai dalyvių mažoka, bet produktas vietiniams naujas tad reikia laiko kol įsivažiuos.
| 05 Geg 2016 07:04 |
simioras
Užsiregistravo: 24 Bir 2012 15:22 Pranešimai: 649
tai kad latviu kvaduose 4x4 nekazka is vis,o siaip gal ir gerai nereiks "savaites" laukt prie starto atsistojus !
| 05 Geg 2016 09:05 |
apPasaule
Užsiregistravo: 24 Bal 2016 19:30 Pranešimai: 21
Miestas: Ryga
Technika: KTM
Some additional clarification about Tourist class: the number of participants in a team – at least two. There must be at least two machines which can be of different types. For this class, competition results will not be calculated and winners will not be determined. Teams who have successfully visited all check points will receive diplomas. There may be special prizes, for example, to teams with the most attractive photos at check points.
Dopolnitelnaja informacija o Turist klasse: dolzni bit ne menee 2 ucastnika i ne menee 2 masini. Rezultati i pobediteli ne budut opredeleni. Komandi kotirije vozmut vse kontrolnije punkti, polucat diplomi. Mogut bit i specialnije prizi, k primeru, za samie atraktivnije fotografii u kontrolnih punktov.
| 06 Geg 2016 16:03 |
tomasbrp
Pocemu ocin mala ucastnikov iz LV?
| 06 Geg 2016 16:05 |
apPasaule
Miestas: Ryga
Technika: KTM
tomasbrp rašė: Pocemu ocin mala ucastnikov iz LV?
Išsiųsta naudojantis SM-G930F Tapatalk 4 Lt Počemu malo? Boļše polovini iz LV. U nas takoi format v principe pervii raz, v Ļitve - mnogo ļet. Dļa pervoi gonki horošii pokazatel.
| 06 Geg 2016 16:17 |
apPasaule
Miestas: Ryga
Technika: KTM
We have created a sample, test GPX file that you will be able to load in your navigators, telephones, computers, try printing maps etc. This is for testing the format. Exactly the same format file but with many more waypoints and a different track will be loaded into your Garmins by InfoEra and provided on appasaule.lv site at 19:00 on 13th May. Please check on http://www.appasaule.lv/?lang=en - will be posted latest on 7th May. Mi sdelali testovoi GPX fail stobi vi smogli postavit v svoih navigatorah, kompjuterah ili telefonah, poprobovat pecatat karti itd. Eto dla testirovanija formata. Tocno takoi ze format no s bolsim cislom tocek i drugoi trasoi buded vlozen v vasi Garmini InfoEroi i postavlen on appasaule.lv v 19:00 13 maja. Pozalosta smotrite http://www.appasaule.lv/?lang=en - fail postavim ne pozdnee zavtra, 7 maja.
| 06 Geg 2016 20:18 |
apPasaule
Miestas: Ryga
Technika: KTM
TestGPX file is published here: https://failiem.lv/u/xefqtn9b#_Some changes in the latest Competition Regulations v11: -Track Length (including Special Tests) – up to 110 km -Number of check points – up to 40 -Time limit – up to 8 h Tourist class - track length up to 100 km, time limit - up to 7 h.
| 08 Geg 2016 09:27 |
apPasaule
Miestas: Ryga
Technika: KTM
Additional information: there is no petrol station in Tome. The nearest stations are in Ķegums, Daugmale and Baldone. The only shop in Tome does not accept payment cards, and there is no ATM in Tome, so bring some Lithuanian Euros.
| 10 Geg 2016 13:07 |
apPasaule
Miestas: Ryga
Technika: KTM
For a small intrigue - pictures of the actual WayPoints of the track https://www.facebook.com/media/set/?set ... 906&type=3
| 10 Geg 2016 18:38 |
tomasbrp
Very nice views, Paulius has something to learn about marking signs from you Išsiųsta naudojantis SM-G930F Tapatalk 4 Lt
| 10 Geg 2016 19:38 |
Dabar prisijungę |
Vartotojai naršantys šį forumą: Bing [Bot] ir 12 svečių |
